5.5 hp evenrude fisherman l963
jay_merrill
Re: 5.5 hp evenrude fisherman l963
I hear you on the safety issue - the only thing that I didn't like about them is that the idea of getting in any kind of a "head on" collision scared the heck out of me.
The cool thing about the older buses, though, was that the motors were pretty much the same across the platform of Veedubs, so you coud swap stuff around easily. The motor change that I did on mine took me 4 hours total - two motors out and one back in!
The one thing that I always wanted to do to mine but never got around to, was to stretch the body by putting a plug in the middle. I had this plan to buy another bus and chop out a section of body from behind the side door to just behind the rear wheel well. I was then going to cut mine "in half" just ahead of the wheel well and weld the thing back together, with the plug added. The idea was to then put a tag axle in the newly added, 2nd rear wheel well and also to raise the roof from just behind the front seats to the rear of the bus. Final touches were going to paint the thing in Greyhound colors with a dead mutt, on its back with its tongue hanging out, on the side. I would have, of course, also painted "Deadhound" on it!
Blame the idea on "wacky tobaccy." We came up with a lot of weird ideas in those days.
samo_ott
Yeah, engine swaps were a breeze eh! AH, the good ole days...
The stretch sounds like it woulda been cool... too bad you never got around to it.
Burkeke
Well I got the armature plate and the piece below it off and FR was correct. He also was correct about the grease on the bottom of the plates. There is no leak where the shaft goes into the housing so I just need to clean it up and reassemble. What do you recommend for grease on the moving parts below the armature plate?
No more Chilton manuals for me. They have been wrong more than once.
Thanks again for the advice
:redface:
samo_ott
We always listen to FR also!
wbeaton
I just use a sparing amount of white grease or any marine grease.
