Franzel311
- Joined
- Sep 17, 2014
- 62
Hello everyone from Iboats! Winter has Finally come to an end it seems in the Northeast and It's time to start thinking about boating.
I need some advise! I put a early modle 5.7 350 two piece rear main seal engine in my 1990 201 Liberator last season the engine runs great but it shakes bad!...at idle it is fine,then as you raise the rpm'a it starts to shake around 700/750 rpm then gets a lot worse as it comes to the 800's then starts to settle as you get to 1,000 rpm's and after that it's smooth as silk any ideas on what it could be? I got the timing right on the money I pulled the drive back off and rechecked the alignment of the drive to coupler and that's good the motor mounts seem good I played with the carburetor settings then took it off and had it rebuilt put it back on and to no avail still shaking i can make it worse as I play with the carb. settings but it only gets so good and then stops getting better I'm at a total lose I think I'm going to have to bring the boat into my shop over the weekend and start yanking the motor out again and start all over...I want to b able to be in the water by mid April so theirs no time to waist...if any one has any ideas on what it could be I would really appreciate it...thanks iboat world!!!!!
