No Problem
Thread starter- Joined
- Jul 1, 2009
- 5
I had a tuliped valve, on 1 head. I ended up taking both heads in for inspection and cleaning up. Now it's time to put her back together.
1999 Volvo 5.7 gsi throttle body fuel injection.
I have a digital copy of the volvo workshop manual, (thank you very much!!) and it shows the torque specs for the manifold.
But for the heads it shows:
Tighten the cylinder head bolts in sequence in two steps.
1. First step, 30 N?m (22 ft. lb.)
2. Final step use special tool J 36660 and tighten as follows;
a. Tighten the long bolts (1, 2, 5, 6, 9, 10 and 13) on the final step
sequence to 75 degrees.
b. Tighten the middle length bolts (14 and 17) on the final step
sequence to 65 degrees.
c. Tighten the short length bolts (3, 4, 7, 8, 11, 12, 15 and 16) on
the final step sequence to 55 degrees.
The Problem is that I don't have the J 36660 tool. Does anyone know the correct torque settings.
I gotta say, I've learned a lot from this forum. I am grateful for everyone's info and boating stories.
Thanks
Thanks
