PitchFork
Thread starter- Joined
- May 28, 2009
- 313
I was changing the distributor cap and rotor and noticed the rotor would move back and forth back 3/8" to 1/2" by twisting the rotor CW and then back CCW. Is this normal or signs of wear of the pin roller that contacts the Cam?
Also I need to change the gasket on the distributor because it is allowing oil to leak. To change it do I just unbolt the clamp and pull the distributor up and out and then slide it back down with the rotor facing the same direction as it came out? Any thing to look for or inspection of the distributor?
Thanks in advance
Thanks in advance
