5.7 EFI won’t turn over
Tunabass
Turn key and nothing, no click, no gauge activation, nothing. The rest of the dash panel is getting power it’s gotta be electrical going to the key right?
Tunabass
My ignition has three wires. Purple, yellow/red and red/blue. All have 12 volts even with battery off. On it’s the same thing. Yesterday I was getting random alarm at the same time I’d loose 500 RPMs for half a second. Then it alarmed and stalled. 100%?electrical but everything else on the boat works.
alldodge
No gauges but rest of helm. If rest of the helm is things like fish finders, blower, check your the 15 or 20 amp ignition fuse.
Check to see if there is 12V on the red/purple going to the key switch. If there is no power then its most likely the fuse/breaker
Tunabass
20 amp fuse is good. And I have power to all three wires of the ignition and yes everything else on the boat, blower, electronics, lights etc…. After the fuse all wires go into the main harness one goes up inside throttle. Cannon plugs all inspected snd look fine.
alldodge
The purple goes to the kill switch in the throttle handle. If it is pulled there will be no power to the gauges or motor
The yellow/red goes to neutral safety switch and then to starter solenoid
Normally when the kill switch is pulled or bad, there is no power to gauges, but you can still crank the motor, it just won't start
Tunabass
My ignition has a red/purple that is fused and connects to a larger red/purple before going into the harness. The ignition also has a yellow/red wire that goes into the throttle. Then the ignition has a purple wire that goes into the harness.
Tunabass
Yes that looks like it. Are all the circles fuses? What do you recommend I check now? It did this a few years ago (alarm) not failure to start and my mechanic said he just tightened some things up and it stopped. (For about 6 months)
Tunabass
Am I missing something or do I just have a gremlin?
Tunabass
Anyone think it could be an internal ignition switch thing? I’m getting 12.5 volts to it.
Tunabass
Bought a new ignition. 3 prong. Which wire goes where please?
Tunabass
There is no continuity between one side of the ignition fuse and the other. There is continuity from red ignition wire to the side that connects to one side of the fuse. Does that mean there is a break further down inside the harness????
Tunabass
With fuse in their is continuity behind dash at least till all wires entire harness.
alldodge
Sorry been driving
The fuse is blown.
You should have 12V on both sides of the fuse, otherwise its blown
Tunabass
Sorry been driving
The fuse is blown.
I mis spoke. I tested the fuse itself for continuity and it was fine. I meant to say with out the fuse in place I could not get continuity from one side of fuse holder to the other. But when fuse installed I had continuity from ignition switch to past the fuse so that’s not the issue. I’m lost for ideas….
alldodge
If I'm understanding correctly
Power to all 3 wires but nothing is working. I would start looking at grounds.
The ground cable from battery to engine block, then the 10 pin engine connector connector
Bt Doctur
Not possible , if that was true you would be running, with started engaged
