5.7 Engine runs good and dies after one minute
Status
Not open for further replies.
ted4420
I have replaced the ignition coil and rebuilt the carb. The engine starts better and runs strong until it sounds like the ign. is turned on and off a few times and then dies. The owner told me that the eng. died at the lake while he was towing someone back to shore. He said the alarm sounded and he put tape over it so he didn?t want to hear it. I noticed that on the 5.7 wiring diagram on the sticky on this forum has two sensors and a reservoir that have a yellow wire a tan/ blu. and a blk.wire going to the ignition module. The reservoir for the drive oil was empty. The reservoir was filled. Can someone tell me where the sensors that are attacked to the module are located and how I can check this system out? Is this an engine shut down system? Thanks, Ted
Bt Doctur
Re: 5.7 Engine runs good and dies after one minute
Ted, if we knew exactly WHAT you are working on, type of engine, fuel system, ing. system ,outdrive we could give you a more accurate answer
ted4420
Thanks Bond-O For directing everyone to my post. I am new at this. Ted
Ayuh,... It's the Same boat,+ Same problem,...
Stick with That 1,+ this 1 will just die into the archives...
ted4420
Thanks I hope I can fix the problem.
Don S
This thread is closed. Stick with your other thread with all the info.
Status
