Hello all it’s been a long time.
Working on a 1999 Volvo penta Gsi PWTR TBI with a new long block in it. It’s been several years since I’ve had to set base timing on one of these and I’m reading conflicting procedures. Some say specifically to install the shunt and connect to 12v+ before starting the engine, some say shunt but do not connect 12v positive until engine is running (this is how I recall doing it), and I’ve even read it’s supposed to be hot swapped with the engine running which very much so doesn’t sound right.
When I first dropped the engine in I ran it with the engine harness plugged into the distributor to get it warmed up and it ran ok. I stopped the engine and installed the shunt, went to start it again and it blew out the starter almost immediately so I obviously f’d up something. If someone could please confirm what the latest procedure is for a sanity check that would be great! The part number to the shunt I’m using is 885163 pin A blank, B alligator clip, C & D are tied together.
Thanks as always
Thanks as always
