Ryland3210
Thread starter- Joined
- Jul 21, 2015
- 60
This is a 2003 Bayliner with a 5.7 liter Mercruiser EFI 260 HP engine.
Engine starts fine and runs up to speed fine. After running at 3500 RPM for about 30 minutes, the tachometer began to jump erratically higher, while the engine ran steadily. I gradually slowed down to 1100 RPM as I approached a marina. The engine died suddenly. I gave it a little throttle as I normally would, and it started after a few seconds struggling. I did not want to idle, so I gave it lots of throttle. It would run at 2,000 or more RPM, but died again when I tried to drop down to 600, its normal idle RPM.
Once I got it running again, I ran a steady 3300 RPM back to home port, which took about 30 minutes. It ran fine until I started to slow down again. The engine quit again. It took a number of tries to get it going. I smelled gas and immediately turned on the blower. Then I got it to idle at 600 RPM and decided to limp all the way back to port without even using more throttle. Whew! Made it!
Suggestions anyone?
Suggestions anyone?
