1996 gm 5.7 liter(was told 5.7 liter need to verify) v8 2 barrel carb. I just bought this crownline with the current situation this forum has helped a lot so these are my problems and i think i have it narrowed down... cold start good....cold or hot the engine will not rev over 3400-3700 rpms... the engines surges... 3000 rpms runs great but when you throttle down to idle it will die.... if engine surges too long it seems to want to die as well... after it dies it will not start....hour later starts.... when trying to restart it smells flooded.... it takes a while and will finally start after it clears out.... no evidence of water in the oil...previous owner rebuilt carb., still had the problem.... i have put fresh premium gas with b12 cleaner in the tank, changed all fluids and filters, and have begun to assess the problem, the timing seams correct, fires right up on cold start, tomorrow i will hook up guage for fuel pressure, and look at distributor cap, and coil,,, i need to change plugs and gather more information but the exhaust manifold seams to be in the way,, another problem i am having is the throttle shifter does not go into neutral sometimes, i have to go to reverse to hit neutral and then bring it back... is there any adjustment??? any ideas will be appreciated
