silverseal99
Thread starter- Joined
- Aug 9, 2019
- 16
2003 Mercruiser 5.7L Gen+ Alpha/Bravo 2 bbl Mercarb with Thunderbolt V ignition with knock sensor. Ser 0M634166 Mod 4312025RS mated to a Bravo 3 outdrive in a 25 ft sport fisherman.
Issue: Engine cranks, but no spark following extensive engine and hull maintenance.
Background: Bobtail package with less than 50 hours, sat on a trailer for 16 years. Engine ran before latest maintenance (pulled heads, new manifolds and risers, replaced coil and all oil/water/knock sensors). Pulled Ignition Control and Knock Sensor modules and set aside (dry, secure storage) while doing engine mechanicals. Reinstalled everything and attempted test run in driveway. Now it cranks well, but no spark.
Easy stuff: Battery is new and fully charged. Dead man switch is in “run” position, looking at 12.5 volts from the ignition switch with good continuity across the terminals. I’m seeing 12.5 volts at coil (+) terminal with ignition switched on. The gray wire from coil to tach is not grounded. All electrical connectors, wiring and terminals are in good condition and appear to be properly connected including the ground to the ignition control module bracket. No extraneous wires remain except one pre-existing black wire with a male spade connector in the vicinity of the carburetor (I suspect this may be merely a ready ground for setting the timing). I’ve tried a new distributor cap and rotor as well as a known good cap and rotor.
Harder stuff: I’ve run the Thunderbolt V troubleshooting regimen (page 1C-9, manual 24) multiple times with a new coil, a known good used coil, and two different Ignition Control Modules (ICM). I have 12.5 volts to the purple wires on both the knock control module and the ICM. My spark gap tester is known good and I have a good quality VOM. Sensor wheel is not touching the sensor in the distributor. Spec for resistance across the sensor is “not less than 100 ohms” and measured near infinite which bothers me somewhat. Knock sensor, oil pressure switch, water temperature sensor, etc are all new and connected.
What am I missing? I’m looking for a single component (other than the dead man switch) that would kill power to the ignition but am not seeing any. Either something simple that I overlooked, or I have two bad ICMs (or a bad sensor in the distributor). Grandkids are coming on the 20[SUP]th[/SUP] and want to go out in the boat…
Thanks in advance!
Thanks in advance!
