5.7 merc 2002
andy1435
Hi every one
I was see if I am correct on my block drains. I found a blue thumb screw under my knock sensor attached to the same piece as my knock sensor. The reason I'm asking is I just hooked up my super flush and want to make sure I'm not going to pump water into a place water is not allowed.
My engine is a 2002 5.7 merc
alldodge
Re: 5.7 merc 2002
Hi every one
I was see if I am correct on my block drains. I found a blue thumb screw under my knock sensor . The reason I'm asking is I just hooked up my super flush and want to make sure I'm not going to pump water into a place water is not allowed.
If your saying your knock sensor is attached to the same location as your block drain, then I need pics. I think your seeing something that isn't there. The drain is under the knock sensor but it is not the same connection
andy1435
Re: 5.7 merc 2002
All dodge
It's a tee fitting knock comes of straight and then the blue thumbscrew was on the tee
Pete104
Re: 5.7 merc 2002
It is what it is! Water won't hurt the knock sensor, IF that's what yur worried for!
It's dumbest idea Mercury had for mounting that thing!
andy1435
Re: 5.7 merc 2002
Yes y is better explanation. Installed the super flush and hopefully it works.
andy1435
Re: 5.7 merc 2002
My blue thumbscrew had black water residue on it is that normall they probably have never been off
CaptainMak
Re: 5.7 merc 2002
Black water residue or a corroded, non-existent o-ring that's supposed to be there ?
