5.7 mercruiser engine swap
Ayuh,.... It should already have composite head gaskets,....
Run whatever oil pan ya want,...
The harmonic balancer should stay with the motor,...
Thought i read that about the head gasket. That would be amazing. I don't mean to question your knowledge but is there any way i can be sure about the head gasket?
Ayuh,.... I ain't seen a steel shim head gasket in an Oem motor since the '80s,....
I've never seen a steel shim head gasket used in a reman motor,....
The only steel in a composite gasket is the fire-ring, 'n if water gets that far, you've got other bigger problems,.....
Im reading a lot of conflicting reviews on composite head gaskets for salt water. I do trailer and maybe twice i forgot to flush my boat when i got back from a day out. Anyone else wanna chime in?
Hmmm wonder...maybe bad compression? I had 120's BUT i didn't have the carb at at wot. I didn't even have the flame arrestor off
