5.7 Mercruiser on Cruisers INC 2970
mattsoltesz
Hello I have a1990 Cruisers INC with dual 5.7L Mercruisers. Port side done. Starbord side giving me trouble. Starts with startng fluid. If I pour some gas in carb it runs untill gas runs out then stalls. Then just turns over, assuming its not getting fuel. Changed filter, nothing suspicious. Any suggestions? Is there a way to test fuel pressure or blow line out in case of clog somewhere? Vaccum suggestions??
ormjgrouch
Maybe needs a carb rebuild? pretty easy to do, alot of HOW TO DO videos.
NHGuy
You could start by removing the fuel inlet connection and cranking the engine a bit to see that fuel is arriving. Also check the inlet filter for clogs. If it's not that...what he said.
thumpar
If you push the throttle forward while not running do you get a squirt of fuel down the carb throat? If not they you have an accelerator pump issue or no fuel in the bowl. Trace it back from there.
