Hi there, I have a 1989 5.7L omc cobra all mechanical engine ( no electronic egnition or choke, has points and condensor etc...) I feel the problem may be due to weak spark. The last time the engine was running i had it idling and i noticed the tach gauge to be bouncing up and down about a 400 rpm gap, this was when it was idling with a little throttle (1200 rpm) I let the engine warm up, then I shut it off, came back a few hours later ready to go out and it wouldnt start. Turned over fine, but wouldnt catch, could smell gas so i doubt gas is the issue, I'm aware of flooding engines. I think the coil may be the issue I will check out what was suggested in this post when i go back up to the boat on the weekend. But what else do you think the problem could be? Thanks for your time.
Steve
1989 Doral Concept
Steve
1989 Doral Concept
