5.7 wont get to wot
Lake time
i have a 1985 murcruser 300 tempest this weekend it ran great for an hour at 3800 rpm and she started sputterng and cant get it above 2500 rpm and i smelled gas when that hapend 4 plug wires are a bit losse the last time it had a tune up was 05 so this weekend im doing plugs, wires, cap, rotor, and coil is ther anything eles i should look at welll im at it that may caues the same issues
Lake time
or could it be bad gas or ethenal in the gas
Not reaching WOT and smelling gas, my first thought is the carb is flooding, but can be many things, need some testing
Ayuh,.... The fuel filters,....
Ya got a fuel delivery issue, not an ignition issue,...
Lake time
wher should I start first time working on something this old
Lake time
I'm honestly leaning on tune up of the ignition system because I was looking at the fuel pump and I found a plug wire haning and I pulled a plug wire off and the plug was broken I got half of it in the wire and the othe was in the motor hahahahah
Compression test to determine health of the motor (more then 110 psi with throttle held at WOT and 4 revolutions minimum)
Check/replace filters if they have not been changed. Check contents of filter
Check timing
Then go to the Adults Only section and review thru the thread about not reaching WOT
Oshkosh1
Ensign
Ensure your exhaust flappers are still intact and one hasn't come loose and plugged one side.
