5.7Gi cooling system volume
Safisher71
Hi
I am installing a closed cooling system onto my 5.7Gi with 75 hours on the clock. It has previously been raw salt water cooled. Should I flush it with a product like Evapo-Rust to remove rust particles that could block the heat exchanger.
http://www.evapo-rust.com.au/ See the cooling system flush product, I am worried about the copper heat exchanger, anodes and water pump seal.
What is the best way to flush it normally with a hose pipe.
I want to refil the system with 50% anti-freeze and need to know the volume of the cooling system so that I can premix the mixture before adding it in.
Any help or experience will be apreciated.
Thanks
