AShipShow
Thread starter- Joined
- Jul 8, 2016
- 1,803
Hey guys... I'm I'm the middle of my 96 bayliner restoration. I got the boat last summer and promptly pulled the drive and motor to start on ripping everything out (floor, stringers, transom, etc). Been sitting covered since and today I needed to hoist it into the boat to mark and measure for the new front mounts and decided to try and fire it up...
I hooked the battery positive to the starter post, negative to the block. Hooked up the garden hose to the inlet hose. Hooked up the fuel line and ran itto a 5gal gas can. Then made a jumper harness to connect 5 and 6 on the harness plug and touch 7 to start it. All went well and it started pretty easily.
I let it idle and warm up for a few minutes. After I was happy with it, I shut it down by removing the jumper from the harness plug...
then I noticed as the coupler stopped, it actually made a couple revolutions back in the reverse direction before completely stopping.... this freaked me out cuz I thought it might have sucked water back into the cylinders so I ran it a few more times and each time I stopped the motor it didn't do it again. The only other thing i can say is it sounded like it might be running lean.. it stumbled a little when giving it some throttle and even shot apuff out the carb once.
thanks in advance...
