Re: 5.7L Spark and Fuel, But Wont Hit?
Yes, it all has to work together, but you also have to do things one step at a time, in the proper order.
I went back over the posts, and you have a bunch of problems. So if you want to fix them, say so and I will take you one step at a time if you want, or you can try to do it all at once and by committee.
If you want to get it done right, forget the machine shop. They didn't adjust the valves because you put the heads on.
So what do you do?
Take the distributor out of the engine and get it out of your way. It is not needed at this point and probably in wrong anyway.
Next, with the valve covers off, back off all the rocker arm nuts until there is only around 1 thread showing on each. rocker stud.
Next. Find #1 TDC on the Compression stroke as stated in this thread.
http://forums.iboats.com/showthread.php?t=427081
Once you have that, and are sure you are on #1 TDC on the compression stroke, we can move on to the next step.
PS: I don't care if you follow my instructions or someone elses. But stop trying to follow all of them at one time.
