Engine will not run. Has gas and fire but not much in the way of compression. It seems like the valves are not in time with the piston. If I put my finger over the spark plug hole and roll engine over I get a very small bit of air pushing on finger. I can hold it very easy. Then it gets real silly. As I keep rolling engine over I do not get the expected push pull of air that you would expect from a 4 cycle. After TDC on the power stroke I get no "pull" or vacuum as the piston goes down. Does anyone know if this could have jumped inside like a timing chain? Any thoughts on tests?
Thanks Lyle
As you can see I really don't do outboards. This belongs to the guy next door. It has been to the shop but has not run this summer.
Thanks Lyle
