5 horse mariner prop replacement
Mikeyboy
My friend has an 81 (I believe) 5 horse mariner outboard model number 6e3 serial number s110027. He is looking to replace the prop with basically the same one it came with as it is old and the edges are getting fairly boogered up but he is having problems finding it. It is a 3 blade prop and the exhaust does not go thru it. Does anyone know where to find those props or even what the model number might be? Thanks in advance for any help you can provide.
Mikeyboy
Re: 5 horse mariner prop replacement
He may wind up having to do that. I guess they only used the set up he has for a few years so that is making it difficult to track down.
steelespike
Also watch ebay all kinds of props show up you just need to be patient and use many different wordings.
Its also possible it was built by Yamaha.And early Yamahas might be the same.
muskiemike12
I just did a search and found one here on iboats in about 20 seconds. You can get a Solas for about $54 It is for a mariner 4-6 hp pin drive.
Mikeyboy
Thanks a lot guys I will let my friend know.
