5 hp evinrude
dlhill55
I have an early to mid 60"s 5 hp evinrude. I'm having problems with the throttle , it keeps flipping back to the off position once the engine has been started. Other than that the motor runs well. Hope you can help.
Thanks Dave
tashasdaddy
Re: 5 hp evinrude
most outboards are spring loaded to do that, incase you turn the tiller loose.
F_R
Re: 5 hp evinrude
Somebody has had the coils out, right?? They have to be installed so that the ends of the laminated cores are flush with the machined edges of the aluminum posts on which they sit. If they are too far out, they will rub on the flywheel magnets and the rotating flywheel will drag the armature (magneto) plate to the slow/off position.
There is one other possibility: If somebody installed the tapered armature plate retaining ring upside down, the armature plate will flop around and allow the coils to rub the magnets with the same result.
You need to remove the flywheel and adjust the coils back to their proper positon (or turn the retaining ring right side up). When you put the flywheel back on, use a torque wrench to tighten the nut to 40-45 ft/lbs.
dlhill55
Re: 5 hp evinrude
Thanks, it was the coils. I adjusted them and it runs fine.
Thanks again
Dave :)
