5 hp Johnson shuts off in neutral
cenrique
I have a 5 hp Johnson ob that everytime i put it on neutral it turns off. Is it a bad gas line? does it need carb work?. Can somenoe please tell me what could be causing this problem?
Thanks in advance
Carlos
HighTrim
Re: 5 hp Johnson shuts off in neutral
Are you saying after cruising, you will put it into N and then dies?
Does it die suddenly, or sputter to a death?
tashasdaddy
will it idle along in gear, or does it die?
tashasdaddy
Default Carb Needle Adjustments For Asorted Carb Variations by Joe Reeves
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
