50 h.p starter selenoid question . please reply fast !!!!
DVDHIDEOUT
it seems like it takes ages to reply here, or memebers choose who to reply to and who to not, anyways i have a 1987 force 50h.p i was replacing my starter selenoid with a new one, somehow i mixed up the wires together, so now i have 3 red wires, anyways i recalled the set up and connected the selenoid but as soon i connected my battery terminal the starter engaged without me even putting the key in the ignition and twisting it to activate the selenoid, and when i change the wires the other way around i get no start, what am i doing wrong here????? i mean when the battery connects the sttarter starts by itself bypassing the ignition key switch, can someone please email me a picture of the wiring diagram for the starter selenoid . i am pretty sure that one red wire coming from the battery connects to the selenoid while the other black also from the battery is grounded to the block, and then there is the red from the starter which goes in the same terminal with the red from the battery , is this right??? please help me out here . it takes me ages to get a reply. please respond
The Marine Doctor
Re: 50 h.p starter selenoid question . please reply fast !!!!
The large wire from the + side of the battery pairs up with the smaller red wires on the solenoid. The second Larger red wire that goes to the starter gets its own post on the solenoid.<br /><br />There should be a yellow wire that is hooked to one of the small posts..and a black that is hooked to the other. If you do not have the black wire..the soleniod grounds through the case.<br /><br />TMD
DVDHIDEOUT
your are absolutely right my black wire is grounded to the block itslef, now one last question does it matter where i put the connection i mean on the left termianl or the right terminal, does this really matter?<br />thank you for tyhe insight
The Marine Doctor
I do not think it matters...but the yellow one might only be able to reach one side.<br /><br />TMD
