Billmaroney
- Joined
- Feb 25, 2002
- 6
Model #507F8C - 50 hp 1988 Force. Bought boat (13 ft Boston Whaler)from old man not using anymore. Someone I know and trust. He owned boat for 5 years. The only thing he ever did to the motor was have the carb rebuilt one time, water pump changed a few times and replace the battery once. Anyway, boat ran great for me. I used 7 or 8 times about two hours each time. Boat would start on first or second turn of key each time. While the motor ran very smooth, it did not push the Whaler as fast as I thought it would. Top speed was about 28 mph (checked using GPS). I thought it would be more like 35 mph. Some Whaler owners tell me that their 40 hp mercury engines hit 40 mph. My prop is banged up a little and that may make a difference of 3 to 6 miles per hour I am told. (Compression is 125 - 130). Anyway, enough of the side track. My real problem is I now have no spark from either coil. I ran the bought for about 10 minutes the other day at a crusing speed of 18 - 21 mph. Slowed down to near neutral to put jacket on 3 yr old son. While changing his jacket my hand knocked throttle handle into nuetral and the engine died out. Could not get it restarted. Limped home with trolling motor. Used spark plug tester last night with fully charged battery. Flywheel seems to be turning fine, but no sparks from either cylinder. At this piont I have not tested anything else. All the wires seem to be connected. From my reading, I am thinking my problem is either the stator or CD unit. What do you guys think. I do not have a puller to take the flywheel off or a meter to test the stator. Can the stator be tested without taking off the flywheel and without a meter. Any other suggestion. I will buy a meter and flywheel puller if they do not cost too much. Where is a good place to buy parts for this motor?<br /> <br /><br />Any assistance is appreciated.
