kennywaldrop30
Thread starter- Joined
- May 27, 2009
- 7
I am having trouble figuring out how my 1986 50 hp force coils should be wired up . I started off with only fire to one cylinder i took a test light to the back of the coils had power to one but not the other pulled the flywheel noticed i had a rubbed wire into a loose ground screw and a sheared key had fire from one of the coils but weak. I put it back together i have power to both coils now but no fire from either one I have one brown wire on the bottom coil and one blue and on the top I have one white and one blue but have voltage on all the wires and have a negative side and positive side of the coil
