When tilting engine up I need to pull up on the motor to give it some help and then it will go on it's own. It seems to struggle and sometime get stuck. If you go down with it and then back up right away it will work better. Almost seems like it air locked. I checked the fluid level and it is good. There does not appera to be any water in it and the motor sounds strong. Any ideas?
