Johnny Otter
- Joined
- May 20, 2007
- 28
Hi all, just found this forum, and think it's just what I need
. I'm helping a friend out and we are stuck.
I have a couple of questions. The first is simply identifying the year of the engine. The serial number is 3326772A1. I've had a look on some other sites, but can't find a UK reference (if there is one!). The codes seem to refer to a 4 cyl model from 1972, although I would have thought it was more recent than that.
The second question I'm almost embarrassed to ask. How on earth does the engine lift? Is it electrically operated, or manually? I know there is a locking bar through the unit, which presumably changes the angle, and I can see two 'claws' around the bar, which I presume need to be released in order to lift the engine. Would I be correct in thinking that the two dampers are purely to assist the raising and lowering of the engine due to its weight, and as a method of control should the prop hit something and to stop the unit flying upwards?
The engine is electric start, and I've tried the throttle in forward, reverse and neutral to try and raise it.
The whole point is to get the prop in a barrel to get it running, but as we can't lift it, we can't start it
Any help gratefully appreciated.
Thanks,
John
Thanks,
John
