Big Jay
Thread starter- Joined
- Aug 7, 2012
- 256
Hi guys, just wanted to share something here that I've found. Sometimes the ghost in the engine is real!!
I can't help but wonder how many owners, mechanics and backyard tinkerers over the last 50 years have been stumped on this engine.. or worked on it and missed it!
1969 Merc 1000 Tower of Power, serial 2685637. Bought it with an old 16ft glass Crestliner this spring, couldn't get over 4k RPM at WOT and had a rough idle. So I decided to tear it apart and install some carb kits and rebuild the fuel pumps in an attempt to right it.
First carb went as expected, then came the second (middle) carb. I disassembled and soaked it in carb cleaner before wiping it down and blowing it out to inspect for damage and wear. I held it to the light and peered through idle adjust passage (screw removed) and saw "way" too much light shining through back at me.
So I turned the carb around and there is a hole about a 16th of an inch in diameter in the body! Right where the low speed connects to the welch plug chamber. I can only assume it's a factory defect, or maybe a disgruntled mechanic haha... (it's a pretty round hole, maybe drilled?)
I doubt it's the reason for my WOT low RPM issue, but I bet it'll go a long way to smoothing my idle issues!!
Hahaha!
Hahaha!
