50HP Force left me dead in the water in the middle of lake st clair yesterday
riptorn
Re: 50HP Force left me dead in the water in the middle of lake st clair yesterday
Hey, Jason. Sure got your hands full now. Sounds to me like an electrical problem. Try checking all connections. Could be a bad wire. I am new to the Force but trying to learn. Check for bad insulated wires because it shuts down when get hot. Jiggz post Scmat is too small I can't see it to see how the electrical works. Some body here will know the problem. I am curious of the problem
Michigan Jason
no kidding rip! bow rider needs transom and no spark here...coils are good, just not being told to send a spark
Jiggz
send me email address or pm, I'll send you a troubleshooting guide so you can do continuous troubleshooting without having to wait for me to get onliine.
Michigan Jason
what email? :)
Jiggz
Don't discount the troubleshooting guide from CDIelectronics.com also.
Michigan Jason
i need a way to test this ignition pack...
Michigan Jason
I just went outside, put the muffs on, and fired it up.. it ran for 1 minute. I shut it of and restarted it 2 more times without an issue. I noticed that the block was pretty warm for only running for a couple minutes total amongst 3 times starting it so I shut it down. I am lost and in need of help...
foodfisher
Something is getting warm, swelling and grounding out. Look for worn insulation around flywheel. Posting your email was a bad idea. PM's are best for that.
Michigan Jason
hey, if someone wants to email me and help, i am up for it. Engine is starting every time when cold, then like you said, after it warms, it will not start until many hours of not running. I see nothing obvious though... thanks for the help and any more you may give..
Jiggz
Why don't you try running it for about ten minutes just make sure you have cooling water coming out of the snout and the hi-temp buzzer is not activating. OB gets warm real quick even only for a minute of running. What you felt for your engine is normal.
After running it for ten minutes shut if off and then start it again. If it works again, then there's not a whole you can do when it is working. You need to re-create the problem so you can troubleshoot. You and the rest of the forum cannot troubleshoot a perfectly working machine, if you know what I mean. Symptoms are the only indications or telltales where to look.
Michigan Jason
Will do, when i connected the muffs, not nearly as much water was sputtering out as it was when the OB was sitting in a garbage can of water...before I do this, are the muffs sufficient? Or should I go get the can and fill it again?
Jiggz
Muffs should be sufficient since you will not be revving the engine. But if you want to set up a garbage can that is fine too. Pay attention to the hi-temp buzzer or better yet test it first before the test ran. Get a jumper wire and ground the orange wire, switch the ignition to on but do not start, you should hear the buzzer. If you don't you need to fix that first.
foodfisher
Forum rules and Guidelines #7
Michigan Jason
Here is pics of what I am looking at. I will test the buzzer right now and report back. look at the end of my spark plug wires that go into the coil....one is really freyed
Michigan Jason
Guys, where is this orange wire? I do not have an orange one on the motor at all. Only orange one is connected to the horn under my counsel and when i ground it, it sounds the horn. (i just realized my horn button is bad when doing this) But this is not the overheat buzzer right? I cannot find that one.
Michigan Jason
UPDATE: JUN13th 1:15PM EST
Engine was just fired up with muffs on, ran for 1-2minutes TOPS, and I cannot hold my hand on the head where the spark plugs connect for more than 6 seconds without burning myself.
BonairII
Re: UPDATE: JUN13th 1:15PM EST
Pull your thermostat and run without it....should cool the motor right down with it out. Probably a good time to change it regardless. It's a cheap part that ruin a motor in a hurry.
Michigan Jason
is this the unit mounted to the bottom of the head with the wire i just grounded to verify that the buzzer sounded? (it did btw)
Jiggz
You said the engine got hot, but did the buzzer sound? Or the engine stopped? Was there stream of water coming out of the exhaust snout? Was it warm or at least warmer than the intake water?
