50hp mercury leaking water above the cavitation playe
wheelers4life
Should my outboard be leaking water out above the cavitation plate. Is also sounds like it has a miss. I’ll try to attach a video
  • 71304636385__E649491D-38B1-45CF-8631-E2C8F5BCA67B.MOV
wheelers4life
Leak is normal...carbs sound like one is lean. Check under cowl for dirt dabber nest in air intakes
Funny thing about this outboard is if it sits up more than a week it seems to run like crap. I have to pull all 4 carbs off, clean them and then reinstall them. I do not know why. I use ethanol free gas now with Lucas Marin fuel treatment. I have tried sta-bil.
Nothing will get me past two weeks of it sitting. I have all new lines, fuel filter, new primer bulb and tank. I tried a fuel water separater and I could not get the boat to run correctly. I’m guessing the 1998 mercury Bigfoot 50elpt4s is just a bad design. I’ll attach a pic of the carb setup. It’s just like the same year Yamaha.
