Re: 50hp Mercury Starter Problems
Think about this. If the engine starts when you jump the solenoid with a screwdriver, the starter cannot be the issue is it? The bendix however is being chewed up so it does need replacement. Again -- why would you spend a lot of money to replace the starter when all you need is the bendix. Any starter/alternator rebuilder in town can do that for you if you don't want to do it yourself. The bolts are staring right at you when looking at the starter. Disconnect the positive battery cable AT THE BATTERY. Then disconnect the cable at the starter and remove the starter. But even after installation, you still have an issue don't you? Since jumping the solenoid makes the starter work, that says the solenoid or the ignition switch or the wiring between the two is the issue.
