52 Johnson TN-28 - running, but not well
ShoestringMariner
I got my TN-28 back together. It's my first outboard ever, classic or not. I went through the carb, doped the float and reassembled. No drips from the primer or the carb anywhere. The coils were baked, so I replaced those and cleaned the points. Getting it running was not as easy as I expected, nor did it run more than a few seconds before flooding out. I tried tweaking the low speed, high speed, priming,,,nothing could get it running more than a cough or a brief few seconds.
I suspected the fuel as it was 6 month old (premium with stabilizer) and I think I mixed too rich (small batch in paint cup), so I dumped it and started out with new premium and a more careful mix, perhaps even on the leaner side. I put new plugs in it and finally got it running. At first it would only start out of the tank and barely run. It would die as soon as I tipped it in the water. Then after setting the low speed to 5/8 or 3/4 open, it ran and stayed running. There was a lot of backfiring through this y shaped fuel manifold type thing attached to the crankcase, like a shot of compressed air. It seemed to do this more when in neutral as opposed to in gear.
No matter what I did, I could not get this motor to really rev. I don't know if it is running on one cyl or not. It would idle somewhat low with a few misses here and there, and run full throttle but not revving at all like this vid (this is a vid of a TN26). Nothing I did with the high speed idle made any difference unless I closed it completely.
Any thoughts?
Honorary Supreme Mariner
The " Y shaped fuel type thing " is the low speed mixture adjustment at the rotary valve.-------When air spits out of that hole you need to open the low speed needle some.---If you have been running it dry then you will now need to replace the impeller.
steelespike
Premium gas is actually harder for your motor to burn.That's not your problem but a huge waste of money.
I hope your mixing 1/2 pt. to a gallon.?
Disconnect one plug wire at a time see if it will run.
Usually on one cylinder it would still seem smooth but lack power.
Usually struggling in the water indicate a lean condition.Though there are other more serious conditions
that would make it struggle.
tomhath
Is it getting a good flow of fuel from the tank to the carb? The petcock should have a strainer, either that or the shutoff valve itself can easily get partially plugged which will cause it to run lean.
ShoestringMariner
Thanks guys.
Steeles; I run premium because of the ethanol content in regular fuels in my area. I did not know it would be harder to burn...figured higher octane was better(?) I mixed it 16:1 in a mixing cup. What is strange to me is that the high speed adjustment made no difference at all. I followed this article to a tee. http://www.pochefamily.org/outboard/CarbService.html
Racer; I have a new impeller for it, so I didn't worry much about the old one for the initial firing, but yes, I do agree with you...not a good idea. I fiddled with the low speed, and found it worked best at the advertised 5/8 open, but the sneezing still happened occasionally.
F_R
No need to mess with it any more until you find out if it is running on both cylinders or not.
ShoestringMariner
silver_bay
My understanding is that higher grades of gas are blended so that they don't "detonate" (aka knock) without spark in higher compression engines.
