l008com
Thread starter- Joined
- Jun 14, 2007
- 766
My new horn has an air pump that's pretty heavy for it's size. My plan was to cut a block of wood, use 5200 to glue the block to the side of the boat (inside, in the bow below "deck"). But once cut out the block and had the pump on it, I started to wonder. Is 5200 going to be strong enough to hold this weight in place? I've used it for smaller blocks that I use to put wire clips in with. But that doesn't work out to very much weight. This pump on the other hand, is pretty solid. Thoughts?
