'54 evenrude big twin 25 hp producing sludge
todd281
Hi I have a 25 hp Evinrude Big twin that I have been working on . thanks to all for all the advise so far. I have it set up in my test tank, and after running it for 15 minutes I see some black sluge floating on top of the water. I am not sure if this is from the fuel mix, or perhaps the lower end. I am running 24;1 which might be a bit rich. [It smokes quite a lot ] Any advise on a different mix? perhaps 32:1? Has any one noticed this type of sluge in there test tank? maybe I should just takes it out and run it? [it has been sitting for a few years] any thoughts would be greatly appreciated. Thanks Todd
flyingscott
perfectly normal you just notice it more because it is in the tank and because they never really get warmed up in a tank 24:1 is the correct mixture
F_R
Totally normal. I'd be concerned if it did NOT produce smoke and sludge. Hey, they didn't worry about such things in 1954.
todd281
Thanks for the replies, guess I'll take her out for a test run .
