lower carb is not responsive to full throttle?
K kybodyman Cadet Joined May 23, 2009 Messages 21 Aug 11, 2009 #1 lower carb is not responsive to full throttle?
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Aug 11, 2009 #2 Re: 55 evinrude carb problems clogged jet, see ethanol and carb cleaning. http://forums.iboats.com/showthread.php?t=299680
K kybodyman Cadet Joined May 23, 2009 Messages 21 Aug 11, 2009 #3 Re: 55 evinrude carb problems Is it possible to remove and clean the high speed jet without removing carb ?
T tmcalavy Rear Admiral Joined Aug 29, 2001 Messages 4,005 Aug 11, 2009 #4 Re: 55 evinrude carb problems You can remove the needle and spray carb cleaner in there, but it won't clean the carb. Need to pull/disassemble/clean and re-install it.
