55 eVINRUDE FLEETWIN (got hot)
jwh
Hi! everyone,
Looking for your expertise again. A friend has a 55 evinrude 7.5 . He said it was quitting on him. When I started it to see if adjusting carb would help I noticed it isn't pumping any water. So I asked him how long he run it after it kept quitting on him and he said off and on all day. It pulls over very hard( I think from getting so hot) but it does start. My question is is it worth it to replace impeller or is the hard turning over a sign it won't last long.Model# 7518 Serial # 7514-08162. Thanks all. John
jwh
Re: 55 eVINRUDE FLEETWIN (got hot)
Sorry that is Model# 7514 a 1954 evinrude.
HighTrim
Step 1....check compression.
nwcove
do a compression test, it " might " be worth an impeller, those motors are rugged .( the hard pulling could be due to the impeller)
F_R
Might have a broken shock absorber. That pushes the bearing housing up in to the water pump. And makes it very tight. You won't know till you get in there and look.
jwh
O.K. Thanks guys,
I will take her apart and look. Thanks guys John
jwh
I will also do a compression test on it, whats a good compression reading? John
nwcove
jmo, but 75 psi per hole +/- 10 % between cyls would be nice to see, more would be better obviously, much below that could be a worry. ( some small motors will run reliably at 60 psi tho)
jwh
O.K. Thanks John
