55 hp jonson motor wont idle
chrismeister
my 1976 55 hp johnson wont idle properly to troll gotta idle it way up any suggestions<br /><br />could it be out of time??
D
DJ
Guest
Re: 55 hp jonson motor wont idle
every,<br /><br />You can just about bet your carburetors are gummed up.<br /><br />The ONLY way to clean them is to disassemble, clean and install new kits.
chrismeister
ive dis assembled carbs cleaned and checked floats and seals all are in good working order<br />any other suggestions<br /><br />how do i set time?? on water full throttle set or at an idle??
papasage
a manuel will show you how . if you dont have amanual go to the libary they should have one . if they dont have your year modle you can learn the basick way to do it . you can order a manuel on this site. look at the top and click on manuals .
