samo_ott
- Joined
- Jun 18, 2006
- 5,125
Re: '56 Evinrude 30hp coming out of gear
Ok, yes, the lever does remove. I included the shaft with the lever. The shaft does not come out. You do not need to remove the lever, just loosen the screws a bit. Then in the forward position, with a screwdriver, I lift the coupling in the oval port to raise the relative position of the shift rod while the shifter lever stays in the same position. That's how I adjust it.
The shift lever does come off on this one. Just have to remove the screw and bolt and it will slide off. Even when I move the bell crank all the way to the clockwise position with the lever off, it still will not engage in forward. I'm missing by about an eighth of an inch. It's just in between neutral and forward. If I can move the lower shift rod up an eighth of an inch in that brass colored coupler in the leg, it should do the trick, correct? I just need it to pull it up a little higher. What do you guys think?
