I recently purchased a 1956 Johnson Sea-Horse 15hp motor that had been sitting for awile. After cleaning the points,cleaning the carburetor,changing the lower unit oil, and adding fresh gasoline the motor started right up and ran pretty good. Then I noticed grey oil under the motor. After replacing the prop shaft seal and a new O ring on the hub the motor stopped leaking oil. After spending a couple of hours trying to get this together I need some help. The motor goes into reverse but when I move the shift lever to forward the motor stays in neutral and when the shift lever is in the neutral position the the prop will spin a little then stop. I already took the plate off on the shaft and got the shift rod set right but there is still no forward gear.
