oldboat1
Thread starter- Joined
- Apr 3, 2002
- 9,612
I have a 5 hp Sea King (GG9002A) with a lower unit problem. The motor locks up in gear, or partially locks up. I've opened the gearcase a couple of times to inspect and reseal -- adjusted the detent spring to take some tension off the shift rod, although that didn't solve the problem (made shifting smoother, which is an improvement). <br /><br />I think the problem might be the pinion shaft with its shock absorber assembly -- never seen that before, and the parts manual doesn't show the components. My question is this: Are there two springs inside the shock absorber or one? I know mine has two springs -- which may mean I have a broken spring. I thought the mechanism was intended to work that way, with the "top" spring butting up against the bottom one when the mechanism coils. Thinking about it though (and given that I still have the problem), I'm thinking the spring is broken and has to be replaced. <br /><br />Before taking the powerhead off again and disassembling everything, I thought I would first see if anybody has some advice on this little critter.
