57 evinrude big twin 35 won't idle
eolsen
I have the elec start. When I start the motor I give it some gas and it stays running but if I bring throttle back to about the start setting heading towards slow it dies. Any thoughts or how can I adjust?
nwcove
what have you done so far to the motor? ignition carb etc? dont pay to much attention to the markings on the tiller. jmo
HighTrim
Have you done a linc n sync? You use the pointer, not the roller on this model.
What is the idle set at?
eolsen
Yes I did a link n sync with the pointer. I'm not sure how to set the idle, but I'm guessing I set it with the low speed carb needle?
HighTrim
No at the bottom of the control lever, port side of motor, there is the idle adjustment screw. #43 here, on the Exhaust tube and swivel bracket page.
"http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1957&hp=35&model=25532&manufacturer=Evinrude&section=Exhaust+Tube+And+Swivel+Bracket"
