57 fleetwin fuel pump conversion
fvnightowl
quick question, when using the mikuni pulse pump for this conversion why can't you just run the air outlet for the old pressure tank to the air/pulse inlet on the pulse pump? thanks
rjezuit
Re: 57 fleetwin fuel pump conversion
The pump needs a pulse, alternating pressure and vacuum if you will. The air only provides pressure, there is a check valve that prevents the pulsing. If you remove the check valve on the reed plate it "may" work, I cannot really say. Rick
