'57 Johnson 18hp gasket help.
Hanr3
I'm having one heck of a time finding the part number(s) for replacement head gaskets for a '57 18hp Johnson motor, any help is greatly appreciated.
samo_ott
Re: '57 Johnson 18hp gasket help.
I have the parts manual for FD-11 if you want to send me a PM with your email address and request I can send it along. all part #'s are in it.
Hanr3
Thanks! PM sent.
levi_tsk
Ensign
do you need the reed block??
what other stuff do you need??
power head gasket kit?
carb kit?
water pump?
coils?
tune up kit?
- i just had to buy all that for my '56 fastwin its a 15 hp but almost all of the parts will interchange so i have all the part numbers (alot of them are superceded by others)
just curious but why do you have the head off?
Hanr3
carb kit?
water pump?
coils?
tune up kit?
Pretty sure I have a leaking head gasket, or reed gasket. Could be something else.
My problem is Im only getting power from one piston. I have completely rebuilt the ignition system and the carburator. Pretty much leaves the compression or reeds.
samo_ott
Do you only have compression on one cylinder? What are/were the #'s? If you have compression problems it's on the cylinder side. Not the reeds. So looking at the head gasket is a good idea.
