Folks,
I couldn't find this in Search or the manual so I hope you all can help.
There is alot of slop in the gear that articulates with the verticle throttle rod. I can nudge it into position temporarily, but it seems like the teeth are worn. This plays havock with the motor as I lack control of the throttle mechanism /magneto plate. At times I can turn the throttle half from "full" throttle toward "stop" before the linkage even moves the magneto plate. The only way to get the throttle wide open is to pull on the throttle rod end.
If I disengage the horizontal gear from the vericle one (there is a flar face on the gear), I can move the verticle gear with my fingers quite a bit before the vericle rod rotates. Should there be a key in there?
I think this is the last thing to fix before I get the boat in the water.
Is there a way to fix this or do I just need to replace the parts?
