57fastwin,lowspeed jet problem.
smut
[when i removed my low speed jet and outside nut i also got an inner cylinder that the jet seems to thread into now the jet seems to turn the whole assembly making it almost impossibe to adjust accurately , am i missing something.FONT=Arial Black][/FONT]
Chinewalker
Re: 57fastwin,lowspeed jet problem.
That inner cylinder is held in place by the packing and packing nut. Tightening down on them keeps it from turning...
kfa4303
Banned
Ditto what chinewalker said. The needle threads through the "spinning barrel". You should remove the barrel to clean the passage thoroughly, then reinstall it, followed by the packing material, then the plastic packing water, and finally the brass nut the needle passes through. As you tighten down the brass nut it will compress the packing washer, which will in turn compress the packing, which will in turn compress the barrel and prevent it from spinning. Start by tightening the brass nut down about 1/2-3/4 of the way. The needles should still be able to spin, but should also have a bit of friction on it such that it can be adjusted ans stay in place. Once you've got the idle dialed using the lo speed needle tighten down the brass nut the rest of the way. This should prevent the needle from moving while underway. This link wil help you set the carb once cleaned too.
http://forums.iboats.com/showthread.php?t=167352
