FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Know I understand what the gasket is for like I said I was making a biger project than it is .Will do on taping the holes thanks again for all the help going to try and start moter next week waiting for new mercury switch
This is a prop off 1959 evin rude electric shift the holes don't line up is it because it is from electric shift please se attacheed pictures thanks ALEX
No such thing as a 1959 electric shift.--------One hole would be for the drivepin and the other for a cotter pin to keep the cap on.------Note ---there is no difference in a 40 HP electric shift prop and a standard shift prop.--Picture shows the standard shift lower unit.
Have you already done a compression and spark test,If not that should have been the first thing before considering any thing else.Be areal bummer if you do all this work only to find you have no or poor compression #s.Also carb overhaul if the motor has been sitting a while.
Well I have plenty of spark that is really a surprise considering the shape of the rest of the motor. Waiting for gas line hose then the big day. So far I have about 125.00 invested not bad if the motor runs.
Finaly got all the parts for the motor on sat.Motor tried to start but would not keep running kept flooding out removed carb needed cleaning and one bolt was loose mounting carb on engine.I ordered rebuild kit today next try on wednesday.Going to work on electric start while waiting for carb kit starting by hand is a killer. Thanks for all the information on fuel pump worked good so far.
