Re: '58 FD-12 Super Lean
I have a 59 Johnson 15HP some of the same issuses, I though i had good spark on both cylinders. Motor will run on one cylinder. I ended up Replacing the plug wires with new ones to correct my Problem. I also cleaned carb Replaced coils condensers points. All along it was one bad plug wire. Some one told me while motor is at idle pull one of the plug wires off does motor keep running. If it does put plug wire back on. Pull the other off does it keep rumnning?. I had one wire that was not suppling enough spark fire the plug. Hope this helps
