CATransplant
- Joined
- Feb 26, 2005
- 6,319
I just bought a boat with this engine on it. Previous owner reports that it runs perfectly, but has not run it for a couple of years. I know...pig in a poke. I've ordered a service manual, and will be cleaning the carb and replacing the impeller before I try it out.<br /><br />I have a couple of questions, though, that I can address before then, so I don't have to waste time with those issues when I could be working on the motor:<br /><br />1. Since this is a 1958 motor (Model RDS-20), I'm curious about battery voltage. Is this a 12-volt system? I know some cars were still 6-volt back then.<br /><br />2. The key for the ignition switch on the boat is gone. I know that these key switches are different from an automotive ignition. Can anyone tell me what the difference is. I'm going to replace the keyswitch with a plain switch(es) that doesn't require a key.<br /><br />3. The fuel hose for the tank is stiff and cracked and I want to replace it. Anything I need to know? I'll use the connectors from the original hose. I have an original Johnson tank, but it may be from a later period.<br /><br />This is a great place, and I'm sure I'll have other questions later on. If I can ever answer any, as I learn, I'll certainly do so. Thanks for all the help!
