gmarshall43
- Joined
- May 5, 2002
- 214
I have a 1958 5.5hp Johnson, model cd-15. I need to replace the water pump. I was going to take the bolts off the lower end to drop it down to get access to the water pump(impeller). Someone told me that I may have to disconnect the drive mechanism also. If this is so, how do I go about doing it? If neither procedure is correct how do I procede?<br /><br />Thanks
