Those starters during that era were not the most powerful ever made. Everything has to be in top condition. If you pull the starter apart, you probably will find solder thrown from the communtator from lugging it with weak battery or poor cables/connections. If you have to replace the starter, consider one from a newer model. They are longer, and require a support bracket at the bottom end.
